KitchenAid Range Control Panel Dead?
Model No. KGST307HBS4
Part No. 9753562 (1-wiring)
Fuse 9751984
Hi, I have a KitchenAid gas range, model KGST307HBS4. We had a power surge, and now the control panel does not come on. All the touch buttons are unresponsive. The gas burners work, but the oven does not (presumably because the control panel does not). I’m thinking(hoping) there might be a blown fuse in the control panel and the repair parts list says there is one (part 20, #9751984 in the Cooktop Parts List) but the parts websites I have checked indicate this part is a thermostat, not a fuse. My question is: Is there a fuse under the control panel that might be blown and cause this problem? If so, how can I verify this is the case? If not, what else could cause this problem and how would I fix it?
Verified power is restored to the oven.
