KitchenAid refrigerator clicking noise and fan short cycling
I am hearing a consistent clicking sound coming from the lower back of my refrigerator. It sounds like a relay clicking every 5-15 seconds or so. The refrigerator and freezer sections seem to be holding temperature. I removed the back panel and found that the fan is cycling off and on with the clicking. My refrigerator model has an inverter box instead of a relay/overload attached to the compressor. Should I just replace the inverter box?
JP, No, don’t replace the inverter yet. Your refrigerator is cooling, and maintaining temperature. With the condenser fan cycling off and on and the clicking noise it’s more likely a faulty relay on the electronic control board
AP3176836
(Wpl Will No Longer Supply. Contact Wpl At: 800-851-4605 or Mcgregor At: 937-833-6768 X 268 For Rebuild)
and check and clean the condenser and condenser fan motor and blade.
Joe,
Thanks for the response. So, my only option is a rebuild of my existing board? Nobody stocks the new part? Any idea of time and cost of the rebuild?
-Jeff
— Begin quote from jp65;813881
Joe,
-Jeff
Jeff, Sorry but no idea’s as to time and cost. You’ll need to contact the phone numbers attached to the previous post. There may not be a major delay at all, if they have a "remanufactured" boar in stock and ready to go.
