KitchenAid Superba Micro/Oven Combo
kiKitchen Aid Superba KEMC308KSS04 Micro/Oven Combo…
I bought this used about a year ago and have not used the oven. Recently found out it didn’t work. Everything else works fine. The microwave and control panel are fine. We have been using it for months.
The 30amp BUSS fuse is fine (behind control panel) and the #9759243 thermal switch also indicates a good circuit.
I checked the resistance on the heating elements for good measure and they seem to check out.
Any other ideas? The convection fan, temperature settings and everything else seem to be working properly
