We have a broken door latch, spring or ??? on this dishwasher. We can still get the latch to "pop" into place correctly - it seems to stick up on the right side. My husband believes it feels like a broken spring. How do we determine which part it is? We think we need to disassemble the door, but do not have any documentation on how to do that. Any help would be appreciated.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KUDM01TJBL1
Often if you click on the part a new page will open with more views you can then click on them to expand the view.
Check that the door strike (Item 31 in Section 7 ) is OK
If OK you will have to open up the door assembly.
The following should help
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e8b0d2df77cd7e585256cd800643b6d/$FILE/KD01.pdf
Thanks - it will help! again many thanks! We do need to open the door assembly.
