Latch is loose & will not latch
My momma-n-laws dishwasher door latch is loose and will not latch. I dissasembled the door to inspect the latch. It does not appear broken. I inspected the catch on the tub side and it looked alright also. I could not see anything broken and put it back together. I then closed the door and the latch worked. I opened it back up and reclosed it but this time I had to push on the front panel underneath the latch to get the latch to work. I then tried again and now it will not latch at all. Is there a way to adjust this latch. The only part I can see that might be adjusted is the catch on the tub side but it only has one screw going up through it. Any help will be appreciated. Thank you. Alabamabubba
