Leaking dishwasher
We have hard water which caused the inlet valve to clog with scale and sediment. I had the inlet valve replaced (it was very bad off). The next time I ran it, water leaked out. The door gasket had not leaked before and looked fine. Could the sump gasket, having been out of the water level for so long, dried and cracked causing a leak?
