Leaking Door on Kenmore Dishwasher
Our Kenmore dishwasher started leaking the other night, and when I was looking around the door I noticed a thin white piece of flat rubber that clearly had broken, exactly in the spot where below on the exterior the water was leaking. I’m guessing I just need to replace that piece, which was along the bottom of the inside of the door, apparently sealing the door cavity. But I’m not sure what it’s called, and searched of "door seal" and such get me the large gasket, which I think is fine on mine.
Too, is this part easily replaced? The bottom edge of the inside where the seal appeared to be placed is not even; there seems to be some warp in the panels, so it strikes me that it might be a challenge to get it sealed back with a piece that’s basically the size of a small flat noodle.
