leaking icemaker water in fridge
Hi All
I have this problem.
it overflow in my freezer compartment
the water does not stop flowing to my icemaker
what could be the problem
Most likely the problem is a bad water inlet valve on the back of the refrigerator.
Hi Gene
Thanks for the replied.
I did a test and unplug the refrigirator and turn on water no leak
plug back fridge and it took the water and stop.
then ice drop in basket then it took water and did not stop
could it be that part you listed :smiley:
Very likely.
Thanks :smiley: a million your the man:cool:
You are welcome. Keep us posted.
Hi Gene
Thanks alot.
I order part and install it and works like a charm
Thanks a million :smiley:
You are welcome. I’m glad it’s up and running. Thank you for the feedback.
The main control can be tested during a bake cycle from connection 4 pin 3 (red wire with white stripe) to the red wire at connection 2 pin 7 (red wire) for voltage. If there is not 240VAC during the bake cycle and the bake element has not heated at all, the control has failed.
