Is there a way to repair my leaking water dispenser?
Can you be more specific on the problem please?
The water dispenser constantly drips. It more than fills a glass overnight, causing water to overfill the tray under the dispenser and run down the front of the refrigerator. Otherwise ice maker and water dispenser both
work fine.
β Begin quote from Gene;230346
β End quote
Gene: I hope you can give me some info. My GE fridge water dispenser is dripping constantly. Otherwise ice maker & water dispenser is working fine. Thanks for any help you may be able to offer.
β Begin quote from Janielynn;230289
β End quote
is there a way to repair my leaking water dispenser of Kenmore refrigerator Model # 253-51399104?
Janielynn,
Sorry for the delay.
Have you replaced the water filter recently?
If not, then the problem most likely is a bad water inlet valve on the back of the refrigerator (800 on the diagram).
- The water inlet valve AP3192626
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5220057
β Begin quote from esm2010;235261
β End quote
Is it really leaking or itβs just dripping water?
