Leaking Water from where element goes thru tub
Water is leaking from where the element goes thru the tub, nut seems to be stripped it won’t tighten, I guess I need a new nut, is there a gasket that goes on the element before going thru the tub or is it made onto the element!
washer leaking water underneath
