I have a Maytag SIde by Side refrigerator that is leaking water in the bottom of the ice compartment. It takes approximately 2 weeks for an inch of ice to form. It is not any kind of continual leak, and seems possibly intermittent or random. In addition I see some water on the floor by the hinge corner of the freezer door, again intermittent. It may go a couple days with no water, then there is a small puddle on the outside of the door near the hinge corner. There is a line and some sort of small valve for the water or icemaker near this corner but whn I see the water and feel the line/valve locally for wetness, they appear dry. Cannot tell where this water on the outside or inside is coming from . Please HELP!
I have a Maytag bottom freezer compartment. Model # MFF2258VEM5, Serial # K12436993. The refrigerator is about two years old.
This icemaker leaks water into the bottom of the compartment and freezes. Approximately every couple of weeks I have to break up the ice and remove it or else it will leak out onto the floor. Is there a simple fix for this problem. I understand that many others have suffered this same problem. Has Maytag come up with a fix?
Harold H:mad: :mad: :mad: :mad: :mad:
