Water seems to be dripping from freezer on the back wall into refrigerator. the water seems to dripping from thermstat box that gos to the back of rifrigerater up in to freezer. Anyhelp would be appreciated
Thanks I will check that out
— Begin quote from woodchuckie;99517
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it’s stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Part 7 is your drain>http://www.appliancepartspros.com/sect/x/w/y/xwyoykj0sa.gif
That was the problem. it looks like at factory they didnt flatten the medal piece around drain. mettle lip was sticking out just enough where water could just sit ther, off course it froze and caused the problem. thanks again
