my washer leaks from bottom looks like it comes from above the transmission and it makes alot of noise in the spin cycle. any ideas
Sounds like the central seal is leaking and the bearing is damaged too. In order to fix this problem you have to install the triple lip seal & bearing kit.
It comes with the complete installation instructions. Also you have to oder some special tools: the spring removal tool - part number [AP4260929](http://www.appliancepartspros.com/part_details.aspx?part_id=3854720"AP3873487AP3854730AP191107]AP3854720[/URL], the seal nut - part number , the spanner wrench - part number and the central seal grease - part number .
- The part number for the triple lip seal & bearing kit is [URL="http://www.appliancepartspros.com/part_details.aspx?part_id=4260929)
