Leaky Water Dispenser Kenmore 27 side by side (26.5c.ft.)
The water dispenser on the front panel of a Kenmore 27 (26.5C.FT.) Refridgerator is leaking. How does one dismantel the front panel to access the part that needs to be replaced?
Thank you,
Jaime
It’s likely that the water inlet valve on the back where the water supply attaches to the unit is leaking. Disconnect the water line where it comes out of the water valve and see if it’s dripping. If the dispenser just leaks after using it then try the dispenser while it’s disconnected to observe the leaking.
