You have to also check the hi-limit thermostat and the door switch which is in the heater circuit.
The tech sheet shows the expected resistance for the thermistor.
If all OK check from the white wire on the door switch to P6 on the control board with the switch closed. This then is the heater circuit except the control board so if it is OK then the control board is bad.
Thank you for such QUICK response. I have read the tech sheet a few times and I am at a loss as to where the Ohm reading for a properly working thermistor is…
also, the hi-limit thermostat? You are not referring to the fuze in the control panel are you?
I am new to this type of repair so I appreciate your patience with me.
