washer won’t start and shows error code "dr" …I reasd that it could be the door switch or the control board…is there a way to determine what part needs to be replaced?? or is it 50/50 ??
Your machine has built in diagnostics and test to check the components. There should be a tech sheet inside the lower service panel that will tell you how to do the diagnosing and testing.
