LG Dishwasher 1E code
Dishwasher starts by draining, then fills, but will not run. Error code 1E
Hi.
Inlet water error 1E . Not reached to the normal water level in spite of 10 min. water supply .The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound. Take action on Water Supply device. Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker[LEFT][COLOR=#000000]
Read more: [Appliance Parts Pros.com Discount Appliance Parts](http://www.appliancepartspros.com/lg-sensor-assembly-6501dd2001a-ap4457564.html#ixzz2IpT4IsIT"]LG 6501DD2001A Sensor Assembly - AppliancePartsPros.com[/URL]
[URL="http://www.appliancepartspros.com)
Simon.
[/COLOR][/LEFT]
Thank you for your reply!
Problem solved. The wires in the door get stuck in noise proofing tar that acts like a strain relief. Then with the heat and the door repeatedly opend and shut they brake… Mine was the white wire, some times the gray one brakes. Placed electrical tape on tar where wires may get stuck and sodderd break in wire then taped. Works great!
Good job!
Thank you for shearing with us.
Simon.
