LG Dishwsher LDS5811WW IE Drain Error Message
The OE Drain motor was the original code. Then I found two broken wires in the door and thought that might be it. When I was soldering them back together, i shorted out the pcm board. had the wrong breaker turned off. So today I replaced the board, and the first code I got was IE. But I was just thinking that maybe if is all timed, the drain comes on first and then the fill. So if the drain takes too much time, maybe the fill throws a code when it tries to start? what do you think? Also how do you test the drain motor and the fill valve?
Happy holidays to you all!
Glen
