I have an electric LG Dryer that stopped heating about a week ago. Kind of an odd situation in that the dryer was running and then after about 15 min, the power to my entire house went out. This happened twice and since then the dryer has not heated and the power has not gone out to my house again so I can only summarize that the dryer was the problem.
The dryer still powers on and runs, but will not create heat. I tried to run it with the moisture sensor drying or manual dry setting and both do not heat. I run the dryer under moisture settings and the dryer runs for a long time but never heats so I think the moisture sensors are OK.
I took the dryer apart and checked the thermal fuse, high limit thermostat, and heater assembly for continuity and they all passed. So I am confused as to what the problem could be.
Any ideas?
Andy
