LG dryer shuts off after running & will not turn back on
Hello, our LG dryer starting cutting off midway through a cycle a few weeks back. It will run for 10-15 minutes then just cut off… like it is over heating. After it sits for a while (sometimes 20 mins) it will start back up. While it is off the light inside the drum is still on but the controls are all dead.
I called a repair man out & he wanted a ton to replace the motor… said that was the issue. So I bought a new motor and replaced it… still having the same problem.
What other issues would cause it to over heat? Bad sensor somewhere? stat?
Any ideas, I can replace anything on this dryer now (after replacing the motor)!
thanks
