LG french door fridge is not cooling
Hello,
I have an LG LMX25964ST refrigerator that is not cooling.
  1. it has power.
  2. I can hear the fans running.
  3. the compressor is running.
can i get some assistance on what the issue may be or where to look?
In the past I would think it was a relay switch to the compressor but with these new appliances i am not sure.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LMX25964ST
Since the compressor is running and the freezer is not getting any cooling at all, you have a sealed system problem.
This will be an expensive repair as you need a pro.
Often it makes more sense to put those dollars towards a new unit.
Check your warranty as some uniots have a longer warranty on the sealed system.
