IE error code. Changed inlet valve already and that didn’t resolve problem. It continuously fills until the 8 minute alarm. Should I change the pressure sensor? Thank you for your feedback.
I’m getting the same error code thrown by my LG washer. I’d be interested to hear any ideas on what the problem may be. The washer starts the cycle just fine but appears to throw the code after agitating for a while.
In my case, the machine would continue to fill until the internal timer would error out at exactly 8 minutes. After changing the inlet valve and pressure sensor, I have determined that the problem must be with the main board itself. A $200 item. Because the machine is 10 years old, I have decided to move onto a new machine.
