LG is leaking water in freezer and won't go below 45 degrees in refrigerator
My LG is leaking water onto the bottom shelf of the freezer and it is freezing in layers each day. I don’t know the model number - it has a fast fresh cooling system in the door.
the main portion of the refrigerator won’t go below 45 degrees even when I turn it down to the coldest setting. water leaks down to the bottom of the inside of the fridge and leaks onto the floor in large puddles.
Can this be fixed or does it need to be replaced??
