I am having trouble taking the old pump out. I do not see bolts, or anything on the bottom of the washer to take it out. Can anyone help? Thanks
Well I found out it just a little plastic tab in the center at the back of the motor that you press down and slide the pump back. Replaced the motor and have a working washer once again.
