I have an LG side by side that is leaking water. After you release the button to dispense water form the front, it continues to dispense for a few seconds and then drips for 10-20 sec more. Any help would be great, thank you!!
Have you replaced the water filter recently?
The model number you posted is incomplete. Verify and repost it please.
Sorry, there is a SW at the end. I have changed the filter and run a lot of water to get the air bubbles out. This has been a problem for some time and finally have gotten fed up with it.
One of possibilities is abnormal water pressure in the incoming line. Did you check it?
If there is nothing wrong, replace the water inlet valve.
- The water inlet valve 5221JA2006D
Here are the breakdown diagrams and http://www.appliancepartspros.com/parts-for-lg-lsc27910sw-aswclga.html
Thank you for the help. But I replaced the line and had no change so I did the inlet valve as well and had no change. If anything it got a little worse. Any other ideas? Again thank you very much.
