I have an LG model LRSC26923TT that I am trying to figure out what is wrong I have ensured the condenser coils are clean the evap fan and condenser fans are running. the compressor is running. My door indication for temperature does not change. I have removed the PCB and looked it over for any obvious signs of burnt traces or issues. I believe I have an issue with either a temp sensor or a thermistor. The issue started with the freezer not freezing it would work then not work. Then it transferred to the fridge cooling and not cooling and now I am at a point where I am not getting any cooling. Any help or suggestions is appreciated.
Related topics
Lg Control Board Not Functioning | 2 | 1856 | July 13, 2012 | |
LG fridge not cooling | 2 | 692 | May 2, 2016 | |
LG Side by Side Not working Correctly Possible Fault Code | 1 | 1796 | December 31, 2012 | |
Freezer not cooling | 1 | 401 | January 29, 2018 | |
LG not cooling/not freezing | 1 | 122 | November 13, 2021 |
