My LG side by side trips the GFI as soon as I plug it in. It does the same on a different circuit.
I unplugged an 11 pin plug from main circuit board that has just 4 wires.
BK feeds DISP HEATER
BN feeds DEF HEATER and FUSE (melting 72 C)
PR goes to other side of FUSE above
BL(N) goes to other side of DISP HEATER and othe components on the circuit board(guessing its a common)
My water dispenser stopped working when I unplugged the plug, but I noticed on schematic that the PR line goes to the water solenoids. I dis connected at the selonoids and it still tripped.
What is a DISP HEATER? Need help to buy and change the right part.
Oh, when I unplug this plug above, unit runs properly but not sure if I should continue to run the refrigerator.
