So I have completely disassembled and cleaned my LG front loading washer in order to replace the bearings and seals… only to find that the spindle appears to have some wear at the bottom, and the new bearing isn’t a tight fit (I am able to turn the bearing on the spindle). Do I need to install some sort of sleeve to take up the gap? Or do I need a new spider arm assembly?
Related topics
LG Washer bearing problem | 2 | 3649 | December 29, 2012 | |
LG front-load washer, bearing replacement | 1 | 206 | July 9, 2022 | |
Replacing tub bearings | 1 | 137 | January 9, 2019 | |
LG washer bearings? | 1 | 525 | June 4, 2015 | |
LG washer extra part? | 3 | 557 | April 28, 2016 |
