I am planning on replacing the bearing/seal in my LG front load washer #WM2688HWMA. We have had the washer dryer combination for 7+ years and have a few questions before we start. Are there any other parts that we should consider replacing while the machine is apart? Are there only 1 bearing and 1 seal that needs to be purchased? Any suggestions or comment as to things to look for as we dissassemble and reassemble the machine?
Related topics
LG WM2487HwM - separating inner tub from outer for bearing replacement | 5 | 3702 | April 20, 2018 | |
LG washer leaking at back bearing and seal | 3 | 3220 | July 17, 2011 | |
LG Washer bearing problem | 2 | 3649 | December 29, 2012 | |
Replacing drum bearings | 0 | 6542 | August 9, 2011 | |
LG front-load washer, bearing replacement | 1 | 206 | July 9, 2022 |
