Hello All,
As stated in the post title, my washer has all of the lights. We can set spin, rinse and everything else but when we hit hit the start button, nothing happens. It should be filling water but doesn’t. I did the diagnostic test on it and the spin and drain was working. Does this mean a new main board? I opened it up to look for loose connections but everything seemed set.
I just want to make sure I don’t waste a hundred buck on a board if I don’t need it.
Thank you,
Ken
