the lid lock latches (the grey tab/latch pieces) were snapped off :mad: by a worker - long story. the LH lock is not corroded & only the latch is broken. can I find this part anywhere, or do I need to by the whole LH lid lock? thanks!
[SIZE=3][FONT=Calibri]Sorry to hear that I have done a lot of work on my FAV6800A and FAV9800A on this and other forums. You will need the whole L.H. lid lock. Save the assembly push/pull relay, magnetic reed switch and the case haves may come in handy. Watch out for breaking plastic latches on the case halves of that Lid Lock assembly.[/SIZE][/FONT]
Only the L.H. Lid lock is required for normal machine operation for owner/DIYrepair.
thanks so much. I figured I would need to buy the whole thing but thought it was worth a try. I have read all your posts on the Neptune - so informative!
I have a washer that I purchased new in aug. 2011. I recently moved and some friends moved it for me. Nothing was wrong with it before the move but now when I went to wash laundry found that it will wash but makes a loud rattling noise upon spin cycle. Can someone please help me
I am thinking one of the support springs broke or came off in the move, or one of the pads on the frame or there might be a crack in the support structure.
Take off the cabinet and check things out. You should know that sometimes after a move the tub is just not sitting right on the support structure, and after using the washer for a time or two it corrects itself. See if that happens first.
