Lid Switch replacement
How do I get to the lid switch to replace it?
:confused:
Check My other post, I just wrote a book on how to do it on a Whirlpool washer, Thanks:)Salhasan2003 is the post you need to read.
Sure, for YOU, anything!!! After you have rotated the console panel back, unplug the 3 wire plug, about 1" in from the rear corners are 2 gold colored flat metal clips, insert a flat blade screw driver into the FRONT slot and pry towards the REAR of the machine, with these 2 clips removed, tilt the cabinet foward and remove from the machine.
