Light Out
The refrig light does not come on (verified bulb is not burned out). Also, the front control temp setting lights are not illuminated. Refrig appears to be working fine otherwise. Can anyone help me determine what part(s) are needed to fix the problem? Thanks in advance.
There are two or three light bulbs in the refrigerator part. If no one light works then the problem is a bad light switch (#8 on the [AP3108436](http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=960232&&model_id=5139029"]break down diagram[/URL]).
If only one of them does not work and the light bulb is fine, then the problem could be a bad socket or a broken wire.
Here are the break down diagrams for the Whirlpool refrigerator http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=944001&&model_id=5139029
Gene,
Thanks for the help. I will order the part today. Sincerely I appreciate your reply.
Mark
