I have a whirlpool quite partner 2 dishwasher and it is not working. I control panel lights do not come on when I push them to start the dishwasher. I checked the circuit breaker and it is on. can you help
You will need to check and see if the thermal fuse is bad and will need to be replaced on the unit. If so, make sure you use all the parts sent in the kit. AP4423189
