I am looking for a wiring diagram for my refrigerator. I believe my defroster is on constantly.
The schematic is behind the control panel. If nothing running and unplugging fails to get it running, you probably have a bad adaptive defrost board AP3109394
When I turn on the water to the refrigerator and it keep coming out the door . Replaced the water valve and let 10 gallons drain. Can you supply me with a schmatic .I need to check weatherm I hooked it up correctly
