Low Gas Flame
I Have A Model Ge Cgp350setss Gas Cook Top That Replaced An Electric Cook Top . The Issue I’m Having Is The Burners Are Hard To Lite( Long Time To Lite) Like If There Was Little Gas Coming Out. No Line Restrictions. Had The Ge Repair Guy Out Because The Unit Is A Month Old. He Said That Flash Back Device Needed To Be Removed; So I Did With No Change In Flame Operation.it Seems Like The Regulator Might Be The Problem. The Regulator Is Installed Horizontally, Due To The Fact There Is Not Enough Room With The Built In Oven The Wife Bought. The Repair Guy Said The Flexible Yellow Gas Line(bought From Lowes; For A Gas Cook Top) Might Need To Be Changed To A Larger Size. But The Fitting On The Cook Top Is 1/2". The Gas Line Stub Out Of The Wall Is 3/4" To A Shut Of Valve, Then A 90’ Elbow. That’s Where The Flexible Gas Line Connects To. From There Into The Regulator, Then Reduced To 1/2" 90’ Elbow Which Then To The Supply Pipe From The Cook Top Which Is 1/2".
Any Help Or Info On This Would Be Greatly Appreciated!!
Thank You In Advance
