lower door seal installation
I ordered a lower door seal 4172127. It appears that the channel in the seal is larger that the bottom of the door. Do I glue the seal on, or am I doing something wrong.
This seal should come with the installation sheet. Have you received it?
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=238641
Yes I did receive the instruction sheet. I doesn’t tell you how to install the lower door seal. I does explain how to put the tub seals in. Any suggestions on the lower door seal? My old on was laying on the lottom of the door opening, so I couldn’t use it as a reference for the new seal.
I’m not sure which instruction sheet you received. The correct instruction sheet is attached to the reply.
