Lower Ignitor, No Flame
After reading a bunch of threads I am thinking I have an ignitor issue. When setting oven temp, the ignitor will glow red. I did read somewhere that it should be glowing white and if it is glowing red that is an indication of a failed ignitor. If glowing red the current draw is insufficient to open the gas valve…no gas=no heat! My top burner also glows red but it is lighting properly. Any suggestions are appreciated…cold meatloaf just ain’t cutting it!
:frowning:
