I needed a new condenser fan motor and need to know which termainals are for hot and which are for ground. The replacement motor has 3 terminals in different places. The one i took out had an orange wire for hot and a blue wire for ground???(i think}, and a third wire for ground{i’m pretty sure of this one}. This is an older fridge and has had some work done to it, i would guess.
Sorry but I cannot find any info on this unit.
[COLOR="Blue"]
The one i took out had an orange wire for hot and a blue wire for ground???(i think}, and a third wire for ground{i’m pretty sure of this one}.[/COLOR]
You cannot have 2 grounds.
You should have had:
1 hot - connects to one side or the motor winding
1 neutral - connects to the other side of the motor winding
1 ground - connects to the body of the fan
Perhaps the above will help.
