Magic Chef RV Oven quit working, top burners are fine
Help please. About a month ago, the pilot light quit working on my Magic Chef RV oven but I could still light the oven manually with a match. Today, I tried to light the oven and no gas will flow to the oven at all no matter the position of the oven knob. All of the top burners are still working fine. I’m inclined to think this is a thermostat problem or a pilot light problem. Is it possible that both of these are bad? My husband will be able to fix it if you can help figure out what part is bad.
Everything in the oven is controlled by the thermostat, including the pilot. There is a thermocouple on the pilot assembly that is attached to the thermostat, but since the oven worked even when the pilot was out, that would suggest that the thermostat assembly is faulty. The thermostat for your oven is available below.
http://www.appliancepartspros.com/whirlpool-thrmst-ovn-7515p046-60-ap5690792.html
