Maytag Atlantis spring hooks ?
I just replaced the hub bearing on Maytag Atlantis washer. When re-installing the spring hooks, there doesn’t seem to be much tension in the spring. I’m worried I don’t have the spring hooks installed in the proper orientation, but don’t see how else they can fit.
Would someone look at the attached picture and give me some advise.
Thank you,
David
