My Maytag washer has been acting up in the past few weeks. It started out with loud noise when the tub was spinning. Now it has completed stopped spinning. I have so far replaced the Washer drain pump, Thrust bearing kit and the drive belt. The motor seems to run, but tub won’t spin. Anything else that I can check?
try testing your lid switch
