Hi all, newbie here. Tried the search, but couldn’t find a situation exactly like mine.
Machine goes through wash cycle, then stops while still full of water. Does not drain or spin. When this happens, jiggling the main control knob usually causes the machine to proceed normally. Sometimes the knob will have to be pushed in, spun around back to the spin cycle and pulled back out to make it advance normally. Bad timer maybe?
Thanks!
