My maytag bravos mct will not finish a cycle. It fills spins agitates drains quickly and everything just fine. It gets stuck on the final drain, however. After all the water is drained and gets ready for its final spin, I can hear the drain pump still running and it keeps agitating back and forth. The drain pump will run and the washer will continue to agitate until I cancel the cycle. The washer won’t ever go into its final spin even though it has no problems spinning earlier in the cycle.
I have taken the drum out and found no obstructions and no water (drain works fine). F71 error code when running diagnostics. I have also filled tub with water and rinsed several times so I know it isn’t a suds problem. Please help!!
