Maytag Centennial not agitating not dogs
Hello all, I did search so please forgive if this has been covered anywhere else.
My maytag washer will fill, spin and drain but will not agitate. I have pulled the agitator and the dogs are fine. Splines on shaft and lower agitator are fine and engage well. When you use it it will move the agitator slightly wth clothes in the machine. With the agitator pulled, the shaft will spin in either direction. This is a direct drive unit. I am guessing that there is something in the trans that is broken, worn or out of place. Every place I look at are instructions on replacing dogs or drive couplings for the drum. Neither of these seem to be giving me issues. I appreciate any and all help. Just wanted to check in with more intelligent people before I pull more stuff off and mess up something big because I am overlooking something small. Thanks KC in Georgia.
