Sticks in wash cycle right before rinse with heating delay light on. Move the knob manually to rinse it will complete cycle. Already put new timer in and have same problem.
I mhaving same problem with my dishwasher/ same model also.
Did you do anything to diagnose the problem? Did you follow the instructions from the previous replies?
It completes cycle with temp sensor off
mine also completes cycle with temp. sensor off.
Most likely the problem is a bad boost thermostat (#15 on the diagram), but here is a small chance for the control board to be bad too. In order to provide the correct part number for the boost thermostat we need the serial number of the dishwashers.
