Maytag does not cool but light is on
I recently acquired a Maytag refrigerator whose freezer worked, but lower section wouldn’t cool. I replaced the evapertor fan motor and all was great … for about 2 days.
Now nothing seems to work except the lights. No fans are running, there is no clicking sound when the refrigerator is plugged in - nothing.
I’m thinking it’s something simple - like a switch or relay.
Anyone have any ideas?
Here are your parts, includes a wiring diagram.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MTB2156DE
You may be stuck in a defrost cycle or the thermostat (temperature control) is bad.
Turn the thermostat back and forth.
If the unit fires up I would replace the control.
Turn the defrost timer (Item 15 in Section 2) cam. There is usually a hole in the cover to let you do this without having to take anything apart.
If it fires up I would replace the defrost timer.
If both the above do nothing unplug the unit and remove the thermostat and check it’s contacts when it is set to cold.
Should be 0 ohms.
Thanks denman. The temperature control was the problem.
Hi.
Check if:
-240VAC present
-belt switch is closed
-start switch is closed
-thermal limiter closed
-timer contacts B and C closed
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5217359
Simon.
You are welcome.
Simon.
