Maytag Door Hinges
This is a range with an upper and a lower oven. The lower oven door is not closing tight at the top - it is proud of where it should be by 1/4". There is no solid obstacle to closure - I can push the door closed, but it springs out.
The gasketing looks to be in good shape and not the cause of the problem, so I must suspect the hinge(s). How do I get the hinges out?
Thanks.
Mike
