easy question i need to remove the front to get to the gas valve i want to check pressure . it was converted to propane some time ago not sure if they set up valve right wife has always said drier not hot enough… vent is clear.
question??? how do you remove the front it says 2 set screws at front bottom i cannot see any screws…am i missing something??
