Maytag dryer gas coils
In looking for gas coils I find the two coils are replaced by one number. Does this number give you two coils? If so, are they like original, one with two wires, one with three wires?
This one part number is for a kit included both coils.
It fits all dryers with two coil gas vale made by all manufacturers.
Here are the break down diagrams for the Maytag dryer [URL="http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=806946&&model_id=26697)
how do you remove panel?
Which panel are you wanting to remove?
Nat
front panel on kitchenaid dishwasher #kudu03ftss0
Here’s the parts breakdown http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153267
You are doing to have to remove the inner door lining to get to the screws for the handle.
Study the breakdown and you can see how to access the front panel.
Nat
Can find no specific info on this unit with the given info.
[COLOR=Blue]
The temperature on my oven always runs much higher than I set the dial to. [/COLOR]
Note that most ovens allow you to calibrate the over +/- 35 degrees
The temperature sensor is intact and in the correct place.
Sensor can look OK and still be no good. See below on how to check it.
http://www.applianceaid.com/elecrange.html
See #7
[COLOR=Blue]
The oven door is not what you call tightly shut, would this cause the problem?[/COLOR]
Doubtful but if it is causing the temp sensor to get a draft and see a cooler temp than the rest of the oven it theoretically could.
